need a manual or tutorial for android 5.1 on nexus 5!!
Bell has a great guide for the use of Nexus 5, BUT it does not comply with the update of android 5.1. Anyone know of a guide for the android 5.1 on the Nexus 5
Yes it did the update to loopoop you have call goolge request a call back from goolge nexus 5 not the best because worst system a valble I don't rekmend nexus of the error Samsung or Sony expara not bad phone quit with less error message but ones time old problem as sealed in battery not smart thing is vary dangerous thing just ask questions if there error won't let you turn off they should tell you
Sorry don't know what the above response says at all so I'll direct you to YouTube, any time you want to learn anything just search YouTube
Paul, this is a link to the bell tutorial for use of the Nexus 5, android 4.4. http://support.bell.ca/Mobility/Products/Nexus-5.tutorials I would like to find something similar for Nexus 5, android 5.1 I did check youtube, a lot of good videos but not what I need. Thanks, John.
Most of the tips from the Bell site tutorial are derived from Google's Nexus support site. I managed to find an Android 5.0 Quick Start Guide and there's also an app that offers helpful tips and provides proactive troubleshooting to help you get the most out of your Nexus 5. [b]Nexus Help Centre https://support.google.com/nexus/# [b]Android 5.0 Quick Start Guide (pdf format) https://static.googleusercontent.com/media/www.google.com/en/us/help/hc/images/android/android_ug_50/Android-Lollipop-Quick-Start-Guide.pdf [b]Device Assist (App) https://play.google.com/store/apps/details?id=com.google.android.apps.cavalry&utm_source=nexushc
Most of the tips from the Bell site tutorial are derived from Google's Nexus support site. I mana...You are helpful Master !
Can you tell me I phone 5c different and benefits between Samsung..É Your time appreciate it and responde Krisz
Can you tell me I phone 5c different and benefits between Samsung..É Your time appreciate it a...Unfortunately, I can't answer your question because I have nothing to compare to the iPhone 5c. You have to provide the model name, (e.g. Samsung Galaxy S5), or the model number of your Samsung phone. It's also recommended you start a topic of your own so that you can get a quicker response from others in the community. Click the link below to start a new topic. 🙂 http://community.koodomobile.com/koodo/topics/new
