my unlocked motorola has my koodo sim card but isn't using data when i'm away from wifi
I bought a motorola 3G unlocked from Staples in Canada. I put in my Koodo sim and it appears as though I am connected (the triangle is full/white), however, whenever I am not on a wifi network, I don't receive any emails, social alerts, etc... except for text messages through messages (not hangouts). Any idea what is going on here?
Hi Megan. Make sure you have you have data turned on in your settings under data usage and Koodo's APN settings below in your APN settings
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save.
Allan wrote:
May seem simple but is your data turned on?
I already said that mate
