You need to import your contacts from the sim Enter your contacts and hit the menu key Select import from sim They should be there. Btw you should sync your contacts with Google instead of your sim. Makes it much easier to manage.
Chad burr is correct, especially now a days the new phones are always requiring a different size of sim so relying on your sim for your contact information can be painful down the road. Look into saving your contacts through google and good luck importing your contacts off your sim very easy as Chad explained thanks!
Help
Shortcuts
Bold
Ctrl-B or Cmd-B
Italic
Ctrl-I or Cmd-I
Underline
Ctrl-U or Cmd-U
@Mention
@username
Upload image
Maximum file size: 2MB. Allowed image types: .jpg, .png, .gif.
We use cookies to enhance and personalize your experience. If you accept or continue browsing you agree to our cookie policy. Learn more about our cookies.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
