My samsung ace 2 ran out of battery and it won't start!
  • 7 February 2013
  • 7 replies
  • 12 views
Should I switch to a different plan or company or return the phone?
Have you tried charging the phone with the charger it came with?
Have you tried charging the phone with the charger it came with?It's recommended to only charge your phone with the included charger. Also, leave your phone plugged in and let the charger do it's thing. It might take some time but it should start to charge.
Have you tried charging the phone with the charger it came with?Yes I have tried to charge it but it only shows the battery sign going up but it won't start
Have you tried charging the phone with the charger it came with?Have you tried turning it on while it's plugged in? To turn it on you need to hold down the power button on the side of the phone for like 4 seconds. Don't just tap, push and hold it down
Thanks for the great new idea for my website 😉 lol
It has started to work thank you a lot !
It has started to work thank you a lot !was it that you weren't holding down the power button & I you were just tapping it?
