My Samsung A50 won;t work
It was working fine this morning, and I just went to check a text, and it seemed dead.  I tried turning it off and back on and nothing.  I tried plugging it in, but I just charged it yesterday.  I can’t reset it to factory settings or anything, because it won’t turn on.
Best answer by Robert T 29 October 2020, 22:33
If you plug it in the computer, does the computer sees it as a device?
Nope.
Make sure your charger is working by trying it on another phone.
unfortunately, I don’t have another phone to try…
Are the charger and cable original?
Yes, sir.  About 13 months old.
Try this : https://www.verizon.com/support/knowledge-base-225211/
Rats.  That didn’t work either.  I’ll have to try and take it into the store tomorrow.  Thank you anyway for all of your help, Robert!
Do you have another charger you can try instead of a different phone?
I’ve heard of the a50’s just turning off and all they need is to be plugged in and then have the power button held for a really long time to get it back on. (You can try a combination of just the power button, and the power button with the volume up key)
Sorry, Alan, I thought I had replied yesterday.  No other charger.  I tried your other suggestion, but when I went to Koodo today, they fixed it with the power button and DOWN volume button, which fixed it.  Thanks so much for your help, though.
