my phones SIM card does not work what do i do???? it is a brand new phone! i have had it for about 2 weeks to 1 month
my phone says that the SIM card is not inserted when it is what do i do? my phone is a Samsung Galaxy ace 2
Userlevel 3
Did you try a different sim card?is your current sim card activated on self serve?has it worked before?did you try your current sim card in another phone?did you recently port your number?
Did you mean your phone shown SIM card is not inserted even your sim card present on your phone? Yes,Means,There are three possibilities to get this type of issue. 1.There may be a problem in your Sim card so try another one. 2.Check your Sim whether it's properly inserted or not 3.Your mobile is locked to particular network provider. If your problem persists,After trying first two ways means definitely Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit http://www.wickedunlock.com/samsung-galaxy-ace-2-i8160/rs5wp9/ I hope it will be very useful to you.
sarath wrote:
Did you mean your phone shown SIM card is not inserted even your sim card present on your phone...
Never ever go to the site above. Very very bad.
