My phone won't make or receive calls (in Airdrie AB). Service problem?
I have the same issue right night with my LG G3! Not getting any signal anywhere I go
Do your phones say No Service? Unregistered Sim? What message are you getting?
Mine says "calling mobile" "call ended"
Have you tried cycling network on and off, restarting your phone, or pulling your Sim card in and out ?
Yes! Thank you! Restarting worked. Something so simple after all this frustration! Thanks for responding.
Anytime! Glad to help. restarting pretty much anything will fix the problem 7 times out of 10. Even do it a few times just to be sure.
