My phone picks up US networks when driving on Canadian side of Canada/US border.
I live in a community in Canada, bordering the US. My phone picks up US networks when I drive down the river bordering our countries. I've been charged $5 for US roaming, when I haven't been in the US for months. How do I have this credited back to me and keep from picking up these networks without shutting off roaming constantly?
Hello Jan.
In order not to connect to US network, you would need to turn off the automatic network selection in your phone. Also, to dispute any charges, you need to contact Koodo.
I bet you can watch US over the air TV as well!  Radio waves don't respect those imaginary lines we call international boundaries. Let us know what phone you use, and we can provide some suggestions on how to switch off the network selection Robert described.
Typical Android:
Settings => More networks => Network => Mobile networks => Network operators =>
Let the list populate (may take a few minutes in a busy border area) and then choose [b]Koodo rather than [b]automatic.
BobTheElectrician wrote:
Typical Android:
Settings => More networks => Network => Mobile networks => Network...
If you decide to take a trip to the US and want to roam, you would have to repeat this process and revert to automatic or you will have no service.
Typical Android:
When manually selecting Koodo do I select LTE or WCDMA?
Typical Android:
Unless you have one of the few phones that support VoLTE, the LTE network is only used for data.
Don't know why Koodo doesn't have the map of the circle of border area that if you connected with the state you do not get roaming charges. And in the circles you can make call to area codes to he state free, and if in the states call back home free. Am questing they don't what everyone to know it. You can not use data or text in the areas of the states, that is why I turn off my data and do not text when in the states..
GARY FOX wrote:
Don't know why Koodo doesn't have the map of the circle of border area that if you connected...
That would be way more complicated to do then you think.
Driving near Brockville, turned on data, told us we would be charged, declined data usage. Did not use any data. WiFi was off, networking is set to Koodo only. Still got charged $5.00 for US Data why? Tried on line to get this fixed, basically told how not to get charged. Basically got told how to avoid this happening again. No reason to be charged in the first place. Tried to get a number to call Koodo, same crap started all over again. NOT IMPRESSED GETS HARDER ALL THE TIME TO TALK TO A REAL PERSON!
If your cellular network was set to Koodo only, it would not have been possible to receive notification that you were roaming, as you could not connect to the US network. If you were charged for US consumption of data, something different is going on in your instance.
@Howard. In your settings under mobile networks make sure it is not set to automatic. Choose manual and select Koodo. That way you can only be on Koodo and your phone will not roam.
Lets go thru this again, we where to turn on date and where told if we did that we would be charged for roaming, did we wish to continue, we said no. Apparently that didn't matter and we where charged $5.00 roaming fee anyway. Well you say that if it was on Koodo we wouldn't be charged, well it was on Koodo and has been since day one. You keep saying it is our fault, well we will have to go to Brockville a lot more now due to it is the only neurologist that was taking a new patient. If you check our bill you will see there was no data used PERIOD.
Garnet Lawson wrote:
Lets go thru this again, we where to turn on date and where told if we did that we would be charg...
If you said no to easyroam then you will be charged for pay per use. If you are close to the border it is possible to get charged still. If you are wrongly charged you can contact Koodo to have it reversed. To prevent this from happening in the future you can set your carrier from Auto to Koodo.
It was and is set to Koodo, now all I have to do is get someone to talk to me on a phone or in person.
It was and is set to Koodo, now all I have to do is get someone to talk to me on a phone or in pe...
How are you setting it to Koodo? If you have manually selected Koodo the phone cant roam. So this $5.00 charge is not for roaming(something else) or you have mobile networks set to automatic and not manual.
@Garnet the process varies a little from phone to phone.  Here's how it works on my Android phone (OnePlus 5T running Android 8.1 Oreo)... it may look slightly different on your phone but will likely be very similar process:
Step 1:  go into your settings, and find your Network & SIM settings.  If you have a dual-SIM phone, tap on the slot that has your Koodo SIM card (SIM 1 for me).
Tap on [b]Network operators:
Step 2:  tap on the toggle beside [b]Choose automatically to switch to manual:
Step 3:  Click OK when it warns you you will be temporarily disconnected:
It will show [b]Searching... for a few moments (can even take a few mins--be patient):
Step 4: choose [b]Koodo or [b]Koodo 4G from the list to manually connect to Koodo:
After you tap on that, you should see a brief notification that you've registered on the network, and you are all done:
If down the road you are travelling and [b]want to use roaming, just go back in and change the toggle back to Automatic to undo this and allow your phone to roam onto other networks.
