My phone doesn’t work without data
I just recently replace my android cell with iPhone 6. When I use my phone where I needed to use data my phones eats my data up fast and then does not work. When I say does not work, I cannot receive calls, make calls, or text. Wtf?? Help, cause I hate buying extra data. My phone is not pay as you go, I get regular monthly bills.
So are you saying your phone won't work at all, except for using data? What plan are you on?
Go to Settings >Cellular> and turn off data for apps you dont want to use data.
Also you can see what app is using data here too.
