my nexus cannot connect to network it was said koodo is not available so what can i do?thx so much
Check to see if you've accidentally enabled 2G Only or GSM ONLY modes and that network mode is gsm/wcdma auto Koodo doesn't have a 2G network so that's what's probably happening.
yup i choose LTE but it doesnt work either
Instead of just lte choose hsdpa, umts, etc.
but there is only lte 2g 3g
Ok, did it ever connect to koodo? Where did you get this phone? Did you check to see if the IMEI was marked as lost or stolen? http://www.protectyourdata.ca/check-the-status-of-your-device-in-canada/
sir i download an app after that i cant connect to koodo
i delete it and restore to factory settings but still disconnected
What app was it?
it said no service and selected network(koodo) unavailable
nba2k13
sir by the way where to find the gsm or wcdma i did nt see that
Settings...wireless and networks...more...mobile networks...network mode
Well buy from google play it did connect to koodo before but today it didn't work
Do you have another device you can try your sim in? It's possible the sim malfunctioned. It does happen.
no i am going to koodo customer sevice today to check my sim card
btw i enter my iemi num it said it doest lock
Oh and just to be safe. restart the phone and try again. But yeah visiting the kisok is your best bet. Keep us posted
If you have a friend with another sim card, you can test that on your phone too. If it works then you can rule out the phone as an issue
