My chinese android wont connect/register to the network! Please Help!
I just bought a phone from china to replace my slowly dying Galaxy s2x. For some reason it won't register on the network but it did the first time i started it up. Any help? PLEASE! http://www.chinavasion.com/china/wholesale/Android_Phones/Large_Screen_Android_Phones/Android_4.2_Phone_Cubot_-_1.2GHz_CPU_QHD_5.3_Inch_Screen_1GB_RAM_8MP_Camera/
To verify if your device is compatible with the Koodo network, click on the link below and enter your IMEI number. http://koodomobile.com/en/on/switch2koodo-step-1-c.shtml
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which does not work with Koodo
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...The specs for Andrew's new phone appear somewhat confusing or perhaps it's a misprint. 2G: GSM 850/900/1800/1900 MHz 3G: WCDMA 850/2100 MHz The S2x Andrew currently owns, supports these frequencies. 850/900/1800/1900 for GSM/GPRS/EDGE 2100/1900/1700 AWS (hidden), 850 for UMTS/HSPA/HSPA+/Dual Cell HSPA+. I don't see why Andrew's new device shouldn't work on Koodo's network. GSM/WCDMA works perfectly on my S2x.
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...Dennis is right, Andrew's phone is a GSM only phone unfortunately. 😞 It will only work on Roger's network and subsidies.
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...@rikkster, that's because Andrew's S2x has HSPA+ which works on Koodo where the Chinese phone does not
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...WCDMA==HSPA. Same network. Assuming the specs are right, the phone should theoretically work.
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...I just learned something new. Thanks Timo. So WCDMA is basically the network for 3G. And HSPA+ is an update to the WCDMA network for improved speed?
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...My neighbour told me that he checked on his phone he brought from China supported Network mode, he wanted to use it in Canada and he found out that it supports following modes: GSM MODE gsm egsm900 dcs1800 pcs1900 gsm 850 UMTS MODE wcdma-imt-2000 wcdma/pcs-1900 wcdma-clr-850 wcdma-800 I don't know though if he could activate yet or not!
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...@dennis_l, correct. HSPA stands for high speed packet access, which to my understanding refers more to the data carrying portion of the 3G network, while WCDMA is likely the more correct term for the voice portion. All most people really need to know though is that HSPA and WCDMA are typically used interchangeably.
Koodo uses 3G HSPA+ 850/1900 4G LTE 1700/2100 Your phone uses 2G GSM and 3G WCDMA which do...Sorry, I should have specified what I meant that the phone is GSM only. Although this guy on his ad specifies those frequencies, most clones like those are GSM only. I have searched various sources for this phone in particular and everyone else is advertising it as being GSM only.
Is the phone unlocked?
