My BLU Android phone doesn't ring when I get a call? All other notifications make a sound?
I've tried adjusting all my Settings, but nothing seems to work.  It's only an issue when I receive an actual telephone call.
Have you made sure priority mode is off? Which BLU do you have?
I have a Life 1x2 - Android 6.0.1
I think my priority setting is off. This is my first smartphone. The operator is not so smart.
Oop, my telephone ringer is working now!
Thanks for your help!
You say you don't use a carrier. You only use voip. I would check that it might be voip causing the problem and not the phone or another app.
No, I use the Telus network.
You can make & receive calls?  It just does not ring?
Yes, I can make calls.  And if I happen to be looking at my phone & see a message indicating that someone is phoning me I can answer it.
Do you have Bluetooth or do not disturb turned on? Is the ring volume down? Some phones have different volume settings so you can have the volume up for notfications and everything else but down for your ringer.
Yup, I have media, alarm & ring volumes all set at maximum.
No, Bluetooth & Do Not Disturb are turned off.
What about priority mode? Do you have a ring tone set?
Yes, I set a ring tone.
Just tested it by phoning from my land line & it's ringing!
Good news - my telephone ringer is working now!
Not sure what did the trick because I investigated all your suggestions & rejigged a number of things.  Thanks for all your respones - much appreciated!
Not sure what did the trick because I investigate...
YAY!  Thanks for updating the community with your success.
