My android version 5.0.1 nexus 4 phone will not keep my wifi on...why not
  • 25 January 2015
  • 1 reply
  • 3 views
(empty)
Best answer by Paul Deschamps 26 January 2015, 03:04
Go into your wifi advanced settings and make sure you have it set to "Always" for the keep wifi on during sleep setting. If it's not then every time your phone goes into sleep mode (screen dims out) you will lose your wifi connection, this is to help conserve battery and data.
1 reply
