Moto G data connection problem
I have a moto g first gen. there was a huge revamp about a month ago, and ever since, if I want to use my data, I have to reboot my cell every time (because I don't continuously keep it activated), which is getting extremely annoying. Is there a fix? Does anyone else have this problem?
A huge revamp? I'm not sure I follow. Do you mean a system update?
yes...I guess I'm the only one with this problem...
I'm having the same problem with my moto g first gen. It just started about a week ago. I thought it had to do with the data cap that I put in place on it, since I hit my maximum, but it wouldn't switch over to the next cycle when the month switched over. Additionally, once I removed the cap, it wouldn't reconnect to the system until I reset the phone.
Marijke wrote:
I'm having the same problem with my moto g first gen. It just started about a week ago. I thought...
Call Koodo tech support. *611.
