More data, less minutes
  • 27 July 2015
  • 2 replies
  • 18 views
The smallest plan is $30/month including 200 minutes and 100MB. I am more interested in data than minutes, is there a better option with more data and less minutes? I would also like to have voicemail.
What you see is what you get on the website. There's no option that you can choose to get more data and less minutes. Otherwise everyone would be doing it lol. You'll have to just get a higher rate plan if you want more data
Prepaid may be your best bet. Here you can get the $15 base plan plus top up majorly on data. Data also rolls over and doesn't expire as long as your base plan is active.
