Mobile Data on Samsung Galaxy S3 doesn't work
I have entered all the correct APN info, but it doesn't work even though I turn it on. My browser just says i'm offline, and koodo says I haven't used any at all.
Hey Liam,
Could you please show us the APN you entered?
Can you try this?
APN: sp.koodo.com
Proxy: leave blank
Port: leave blank
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http://koo.do/koodomms
MMS Proxy: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: PAP
APN type: leave blank
Once you've done it, select Save/Done. Select Koodo to connect to the network. We also recommend to turn off your phone for a minute and then try to connect to internet with your browser.
Hope this helps.
Thanks
I entered that APN, but still nothing worked
Thanks for your reply Liam! Could you double-check if there's no space on the fields you left blank and also make sure there's none after the values you've entered.
Keep us posted!
Userlevel 4
It might also help to remove the battery for a couple of minutes
