MMS on Nexus 6 not working since Marshmallow update
Answers to FAQ
data is turned on
No data block on account
apn settings set correctly
phone has been powered off and back on
What are some other steps I can take to troubleshoot before just sitting back, blaming it on 6.0 and waiting for a patch.
Thanks 🙂
Userlevel 3
Have you checked the app setting to see if MMS auto retrieve is on? I know it should be off because of stagefright but having it off caused problems on my Nexus 5 so im assuming same thing for the 6?
Kakarot wrote:
Have you checked the app setting to see if MMS auto retrieve is on? I know it should be off becau...
Even with the feature turned off I should be able to tap the image to download it.
But I keep auto retrieve on and it still comes in the form of an optional download that when pressed, does nothing =[
Userlevel 3
I know you should be able to click and re download in that scenario but I was never able to do so on my N5 (personal experience though).  Maybe try using a different default texting app would be next suggestion but chances are is 6.0 issue and your going to have to wait for patch.  Best of luck though friend!
UPDATE: I literally just got an over the air software update.
I then tried sending an MMS and received one in return!
FIXED
