MMS Not working on Sonim XP7700
I now have my data working after changing the APN setting to koodo from Telus.  Data is turned on.  Whenever I am sent a MMS message it does not download  and I get a Message not Downloaded pop-up.  This all worked fine when I was on Telus.
Best answer by MilkyWay 8 June 2021, 20:14
 Where do i find the correct settings? This is what I have for APN settings, what needs to be changed?
APN: sp.koodo.com
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC: not set
MMS Proxy: not set
MMS Port: not set
MCC: 302
MNC: 220
Authentication Type : not set
APN type: not set
APN Protocol: IPv4
APN Roaming Protocl: IPv4
APN: enabled
Bearer: Unspecified
MVNO type: none
You can check the APN settings at the following link and see if it lines up with the settings you currently have on your phone. https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Upon review of your settings, you need to fill out the values for the MMSC, MMS Proxy, and MMS Port sections.
Have you double checkedthe MMS portion of the APN settings to make sure they were entered in right?
APN: sp.koodo.com
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC: not set
MMS Proxy: not set
MMS Port: not set
MCC: 302
MNC: 220
APN type: not set
APN Protocol: IPv4
APN: enabled
Bearer: Unspecified
MVNO type: none
APN: sp.koodo.com
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC: not set
MMS Proxy: not set
MMS Port: not set
MCC: 302
MNC: 220
APN type: not set
APN Protocol: IPv4
APN: enabled
Bearer: Unspecified
MVNO type: none
Thanks so much.  Everything working correctly now.
