Missing or delayed texts and not receiving calls. they go straight to voice mail
phone isn't ringing or receiving some calls. has been in use while I found out it missed some and just put down to resting for a bit missing calls. Some texts come in half hour to two hours after sent but shows sent time x amount before time I actually received. Begs the question, are there more I miss out rugs? have a new plan using old number on Koodo Vancouver Island. Samsung Galaxy note2.
Userlevel 3
Hi, Lyddy According to your description, it looks like it has something to do with your reception issues. First off, where do you live in Vancouver Island? There are some places in VI where Koodo's receptions are not that promising so you should visit the site below to check out if your place is covered:) http://help.koodomobile.com/coverage-long-distance-and-travelling/coverage-maps
Try turning off LTE and using WCDMA/GSM AUTO setting under Network mode or type which can be found in the network settings under more networks in the phones settings menu.
Try turning off LTE and using WCDMA/GSM AUTO setting under Network mode or type which can be foun...
It's a temporary fix, but the issue of Samsung connectivity is being looked at. Not related to signal strength. Will happen most often while connected to wifi. Wish there was a way to do a sticky on this.
