Mail to Text messaging help?
does koodo have mail to txt messaging im trying to set up notifications from my college about events, grades, labs and all other kinds of stuff when i try to set it up the college sends a confirmation number to my phone then i register it. i cant get them message to come through the tech people asked if i have mail to txt messaging in my plan but i dont know what this is please help this would be so awsome
(phone number)@msg.koodomobile.com will come through as a picture message. (phone number)@msg.telus.com will come through as a regular sms message.
so i should register my phone under telus?
this is what it shows and i cant get it to work is it a problem on there end?
BryanG wrote:
this is what it shows and i cant get it to work is it a problem on there end? [img]https://d1qy7q...
So what happens after you enter your number on this screen? For items selected as send to SMS it will send to you as a text and for items checked at email it will be emailed to your email address
its suppose to send me a txt with my confirmation number and then its all good and i get a txt when a new notification is updated
So are you not getting a text with the confirmation number? Under mobile carrier does it say Koodo Or Telus?
yes it does say koodoo or telus ive tried but nothing so i guess its a problem on there end?
Use the email link but use the address as timo suggested
still nothing happens thanks tho guys
