Lost phone during repair process
  • 18 September 2019
  • 4 replies
  • 591 views
I recently purchase Samsung galaxy A70 and had an issue with battery terminal. I sent out for repair on Sept 3 and estimated time for repair was established to be Sept 12. Its been a week since the status on Koodo self serve is unchanged. I called call centre and was directed to contact the Koodo shop. The Koodo shop say it might be lost in transit. What are my options here. Thanks in advance
Did you ask the koodo shop what your options were? What did they say?
They said to wait until the end of the week
Sounds fair. Maybe the package will be found and properly delivered by then.
Follow up with them at the end of the week.
Hey @rrajan - trying to look into your account, but I can't find a profile that matches (can't match name, nor email address that you're using here).
Mind sending us a private message on Facebook or Twitter, and reference this thread? You can ask the rep to contact me and I can help dig into this a bit.
