Looking to buy an unlocked phone with these frequencies 2G: GSM 850/900/1800/1900MHz 3G: WCDMA 850/2100MHz 4G: FDD-LTE 800/1800/2100/2600MHz
Looking to buy an unlocked phone with these frequencies 2G: GSM 850/900/1800/1900MHz 3G: WCDMA 850/2100MHz 4G: FDD-LTE 800/1800/2100/2600MHz . Wondering if will work on Koodo? Thax
Koodo does not offer 2G
Uses 850 and 1900 for 3G
Uses 1700/2100 paired and 2600 for 4G/LTE
It does not appear this phone would work on Koodo.
It do...
Thank. I guess having 850 only will not work or 3g and 2100,2600 for lte?
It do...
There's no guarantees with 850 only. People with phones with one or the other that come on here seems to be a crapshoot. As for LTE, all you'll be able to get is data for sure until VoLTE is launched by Koodo.
Consider checking this site: http://willmyphonework.net/ when looking for phone/network compatibility.
[quote=rikkster]Consider checking this site: [url=http://willmyphonework.net/]http://willmyphonework.net/[/u...[/quote]Thank you very much!
[quote=rikkster]Consider checking this site: [url=http://willmyphonework.net/]http://willmyphonework.net/[/u...[/quote]For a Bluboo Maya on Koodo it suggests you'll get 3G only.
I would not recommend going for a phone that'll get you 3G only in Canada (poor resale value of device, poorer overall experience when using data).
Granted it's dirt cheap in price for the 32 GB storage / 3 GB RAM. Consider that you might pay only a little more for an in-market phone, but you'll get LTE for sure if you get a phone from Koodo. 2017 line-up is promising for new smartphones.
[quote=rikkster]Consider checking this site: [url=http://willmyphonework.net/]http://willmyphonework.net/[/u...[/quote]Willmyphonework doesnt account for LTE-A using 2600 so that is a possibility on this phone.
@Tobico I'm curious what is the model phone you're interested in?
Hi titaniumtux. It's a Bluboo Maya Max 6" phone. Thax
