lg3 wifi isn't starting
I have an LG3.  Everything but the wifi works.  I can't get it to turn the wifi on.  I've had it a few years and never had this problem before.
It might be time for an upgrade. Try factory reset after backing up your phone
Yeah I did the reset
If factory rest doesnt fix the issue, then you can send the phone in for repair or just get a new phone
You can see that he had the same problem : https://forums.androidcentral.com/lg-g3/595554-lg-g3-wifi-bluetooth-wont-turn-why.html
Was it a factory reset or just a normal reset?
Some LG G3 have problem with chips not 100% seated on motherboard. Look at Youtube solutions and (seriously) you will be treated to how to bake a cell phone.
If you have access to eBay.com (US) shipping, you can get a refurb unlocked G3 for less than the cost of repairing your current one. The T-Mobile model works great with Koodo and features wireless QI charging which the Koodo/Telus ones do not have.
