LG X power
Unable to change the notification sound?
So you go to settings, sound, more, and tap notification sound and nothing happens ? Or is there something else?
I do that but the notification sound doesn't change
What kind of notification sound are you trying to change? There are notification settings within certain apps that will allow you to do this, (e.g. email and text notifications).
rikkster wrote:
What kind of notification sound are you trying to change? There are notification settings within ...
Its my wifes phone and she is trying to put a christmas song on for incoming texts
Does she have a Christmas tune downloaded? If you're looking to download some Christmas tunes (or any kind of Ringtone, Notification, wallpaper, etc) download Zedge from the Google Play Store
She has Christmas tunes already down loaded and you pick the tune and save but when she gets a text it goes back the the beep tone
It may be that either the file is in the incorrect format for a notification tone, or too long a file.  Ringtones are easier, as they are longer.
