LG G6 vibration not working
  • 25 April 2019
  • 101 views
My LG G6 is new from August 2018 and the vibration mode doesn't work most of the time.
When i reboot the phone it works for a couple times then stops working fairly fast.
What should I do? Can I get a new phone?
Thanks
Best answer by Dennis 25 April 2019, 20:57
There is a 1 year warranty on the phone
https://www.koodomobile.com/help/warranty-and-repair-policy
You'll only get a new phone if LG determines that it's uneconomical to repair under warranty. For the issue that you are describing, I doubt that. But it should at least be repaired.
Have you tried performing a factory reset on the device?
Userlevel 2
Will they repair it or just give him a refurb?
You'll only get a new phone if LG determines that it's uneconomical to repair under warranty. For the issue that you are describing, I doubt that. But it should at least be repaired.Will they repair it or just give him a refurb?
Whatever is more economical is usually how it goes.
Before sending it in for repair, use the supplied LG backup app to clone your data and settings onto an SD card. The interface is clunky and it seems to take a long time, but it can be a life-saver if service decides to swap your phone for a refurb unit.
