Lg g3 wireless charging
Do LG G3 come with inbuilt wireless charging Qi ?
Nop I don't think so if it's not written on the box then no
Ok. Any way just found out from amazon review that our koodo lg g3 is still doesnt have a compatible wirelless charging cover available.
However you can buy universal android charging Q from anywhere and stick it to your phone in between its cover and back. And your phone will be ready to charge wirelessly
Did u try that... I heard there is no point of using them becasue the battery gets heated up and the charging rate is 500mA ..so it will take a day for full charge
Wireless charging in general is slower than regular cords, but 500mah is pretty bad. That's at least 6 hours for a full charge. My Samsung wireless charger I got for my S6 has at least 1A/hour
Well then i have to search for 1a capacity charger and qi
any update guys?
The canadian version of the D852 LG G3, even with changing the NFC sticker on the back to support wireless charging, still ONLY will support PMA-compatible charging mats, such as the Duracell PowerMats.
