lg g3 notification led not working for incoming messages
I bought an LG G3 last week and it works great except that the notification LED does not blink when I receive a text, email, or any other notification. It works when the battery is charging. I have tried the following:
- Turned the phone off and on after 1 minute
- Removed the battery and turned the phone on after 1 minute
- Verified that the notification led was set to "On" in the settings and accessibility settings
- Installed Light Flow to try to force it to turn the led lights on (as recommended by an online guide).
I have Android 5.0.1 installed, so it was also suggested that this might be a cause? Is that true?
Is there anything else that I should try?
Thanks
Best answer by Melissa 10 August 2015, 18:11
Hmmmm not familiar with that particular phone but I know some phones have settings for the led itself. Have u checked your settings for messages ? Sometimes it's hiding you just need to find it lol.
1 reply
Userlevel 4
