LG G3 MTP PTP NOT WORKING.
LG G3 MTP PTP not working.  When I plug the USB into my computer, it doesn't offer me the option to connect to my PC with the MTP/PTP protocol.  It just charges as though it's plugged into a wall.
It used to work, stopped working after the last update.  What is going on?  I want this feature back.
Best answer by Nabil Koodo 6 January 2016, 14:35
Hi Andrew.
After plugging the USB cable into the phone, touch and drag the notification bar down and touch "Charge phone". Then touch the desired option (Media Device (MTP)), it should work. If you can't access this option, we recommend to visit the LG website and contact the support department http://koo.do/1kLLV7A, you will probably need to install an USB driver on your computer 🙂.
Thanks!
1 reply
Hi Andrew.
Thanks!
