LG G3 forgetting Wifi
Hello Recently I switched to an LG G3 on Koodo, everything has been great except for one issue. On reboot the phone forgets all wifi networks and passwords. This seems to be an issue primarily with the Koodo version, as myself, a friends sister, and another gentleman I've talked to all have the same phone on Koodo and all have the same issue. My wife though, has the G3 on Fido, and has had no such issue with hers. Is this a known issue? If so is there a resolution for it? I have found a way to fix mine by rooting and changing a line in the build.conf file. This is not a fix for 90% of customers tough. This was the only thing that worked, after 2 factory resets.
https://c.getsatisfaction.com/koodo/topics/lg-g3-dropping-saved-wifi-connection
Thanks Chad
