LG G3 App problems
  • 17 August 2015
  • 4 replies
  • 27 views
I recently bought an LG G3 with Koodo in Canada and it is proving to be more of a headache if anything. Currently apps like Youtube and Kik won't load properly. I know Youtube seems to be in an infinite loading loop. My guess is the cause is from switching from Data to wifi. Could someone please help me I want to know if I can actually fix this or just trade the brick of a phone in.
Hi Kiel,
Try restarting the phone, check for updates or even a factory reset on it! By then it should be working for you!
Hi Kiel,
Try restarting the phone, check for updates or even a factory reset on it! By then it s...
I tried a factory reset on Friday night after I got the phone it was working fine until a couple hours ago and the Operating System is the most recent version. All apps are up to date as well.
A little history...
https://community.koodomobile.com/koodo/topics/lg-g3-dropping-saved-wifi-connection?_ga=1.30424575.1...
Nevermind I think I have fixed it I just played around with my data and everything seems fine now
