LG G2, No Mobile Data connection.
Got an unlocked LG G2.. Calls, texts work perfectly but I can't seem to get any data on it at all.. I've tried Factory Reset and just general resets. I don't know if it's worth noting that I am a prepaid customer, I do have data and this is the fourth phone i've moved this SIM card to.. Anyone got answers?
You will need to update/change your APN settings Here is how: http://help.koodomobile.com/plans-add-ons-data-and-other-services/data-basics/how-do-i-setup-data-on-my-non-koodo-phone
Have you setup the apn? Name KOODO APN sp.koodo.com Proxy leave blank Port leave blank Username leave blank Password leave blank Server leave blank MMSC http ://aliasredirect.net/proxy/koodo/mmsc MMS Proxy 74.49.0.18 MMS Port 80 MCC 302 MNC 220 Authentication type None APN type leave blank APN Protocol IPv4 APN roaming protocol IPv4 Enable/Disable APN APN enabled Bearer Unspecified
Timo Tuokkola wrote:
Have you setup the apn? Name KOODO APN sp.koodo.com Proxy leave blank Port leave blank ...
Thanks It Worked!
I ALSO HAVE A same problem
Then try the same solution.
Oh you beaut! Cheers mates! it worked like a charm.. I'm not very phone savy... Much much appreciated!
I dont know why it doesnt work for me! I use LG G2 too , after i update apn setting there is nothing come out!! Can someone help me?
Worked for me! Thanks!
