LG G2, No Mobile Data connection.
  • 25 March 2014
  • 9 replies
  • 2085 views
Got an unlocked LG G2.. Calls, texts work perfectly but I can't seem to get any data on it at all.. I've tried Factory Reset and just general resets. I don't know if it's worth noting that I am a prepaid customer, I do have data and this is the fourth phone i've moved this SIM card to.. Anyone got answers?
You will need to update/change your APN settings Here is how: http://help.koodomobile.com/plans-add-ons-data-and-other-services/data-basics/how-do-i-setup-data-on-my-non-koodo-phone
Have you setup the apn? Name KOODO APN sp.koodo.com Proxy leave blank Port leave blank Username leave blank Password leave blank Server leave blank MMSC http ://aliasredirect.net/proxy/koodo/mmsc MMS Proxy 74.49.0.18 MMS Port 80 MCC 302 MNC 220 Authentication type None APN type leave blank APN Protocol IPv4 APN roaming protocol IPv4 Enable/Disable APN APN enabled Bearer Unspecified
Have you setup the apn? Name KOODO APN sp.koodo.com Proxy leave blank Port leave blank ...Thanks It Worked!
Have you setup the apn? Name KOODO APN sp.koodo.com Proxy leave blank Port leave blank ...I ALSO HAVE A same problem
Have you setup the apn? Name KOODO APN sp.koodo.com Proxy leave blank Port leave blank ...Then try the same solution.
Oh you beaut! Cheers mates! it worked like a charm.. I'm not very phone savy... Much much appreciated!
I dont know why it doesnt work for me! I use LG G2 too , after i update apn setting there is nothing come out!! Can someone help me?
Worked for me! Thanks!
