Koodo... LTE.. help...
my telus phone and service was on Lte 95% of the time.. I switched to koodo and I'm on LTE 5% of the time.. is this normal?
Hello Shawn.
No it's not normal. Koodo and Telus have the same network...
Any ideas of what the problem could be?
Is it the same phone with a different carrier or you switched the phone too?
Same phone, it's a note 3 SM-900W8
Honestly, I feel like it's not my area of expertise .. In my head it should work fine. Did you try doing a hard reset to your phone by removing the SIM card?
Yes.. and I did a factory reset
I would try a new Sim card and make sure it is a LTE card.
Hey Shawn! Is your LTE working now? Keep us posted!
