Koodo LG G3 GPS not functionning using Google maps, Bluetooth not synching with Ford Sync and Wi-Fi not always comming on.
I have Android 5.0.1 on my phone and if I use Google maps the GPS will not activate, and the same with The weather network. But if I turn on my sports tracker program, it wakes up the GPS and then The weather network works as it should but google maps still doesn't. I have done a reset on my phone and it seems to work for a bit then no more. I have removed and reinstalled those apps and same result.
The Bluetooth, I have to turn it off and then on so Ford Sync sees it and connects to it, without that, no go. Wi-Fi is basically the same.
Not very impressed so far with this other LG phone. Previously I had a Nexus 4 phone, which was made by LG and it would reboot on it's on and other issues. Hopefully next time I will pay the extra dollars and go with a Samsung phone, much more reliable, I had a couple of those before.
I suspect that an upgrade to android may solve my issues, but it seems that I have to wait for Marshmallow before any home of fixes, can you assist.
I know I have many issues but I tried to resolve them myself being a server analyst, that is what I do.
Andre
The LG G3 is an android. This may not be the most suitable option for you but have you considered doing a factory reset?
Ahmad wrote:
The LG G3 is an android. This may not be the most suitable option for you but have you consid...
As I mentioned I have done a reset on this phone already, it work for a few minutes then back to not working.
Hey Andre!
Have you tried Chad's suggestion on this link: http://koo.do/1irzpZE ? Clearing the cache in Maps should fix the problem.
Let us know if you still need help!
Also you can check to see if there is an update to your SYNC. you can go to http://www.syncmyride.ca to check and download an update for it if there is
I will check My Sync, but this is a brand new ford escape which should have been brought up to date prior to me picking it up, but worst have happened ! As far as clearing the cache in maps, same crap ! My wife's Samsung Note connects all the time with android 4.4.2, either it's phone related or android version, but so far I think I have learned a valuable expensive lesson stay with Samsung, no more LG, third LG different model with issues ! 2 Years is long with a bad phone !
There was an update to Ford Sync, but no difference I still have to turn Bluetooth off and on for it to sync with my ford. This is very frustrating.
Honestly I think that's a pretty minor inconvenience. I know its not fast enough but at least you know it works. It's probably just a quirk with the LG software. As for GPS, go to location settings and make sure its on high and not battery saving? That's the only thing I can think of. I've never been an LG fan persay except for the G2 when that came out. Their Android interface is a bit immature and the updates are pretty slow.
Thank you Jonathan. Yes location settings are set to high accuracy gps and networks. I sincerely hope that it's just an android issue, but meanwhile I will send my phone back for repairs so they can confirm.
