Kitkat 4.4 is out on Nexus 4
Userlevel 2
I just did the update. It went flawlessly. A few minor changes in the settings menu, but otherwise, it went well.
N4 owners will be happy 😃
It's been out for about 4 days now. You should install the Google Experience launcher, it makes 4.4 awesome. The Apk file is easy to find just Google it and it will come right up if you haven't yet?. and turn on developer settings then turn on ART instead of Dalvik it makes app crashes a thing of the past, I have only had one app crash twice when I first started it after switching the ART then never again.
It's been out for about 4 days now. You should install the Google Experience launcher, it makes 4...
How does ART do for opening apps, multitasking, and battery life?
Userlevel 2
I'm sticking with Go Launcher. I like my Diablo 3 theme 😃
How do you get the update??
Go to your settings - About Phone - software update - check for update. Make sure to update on a full battery while plugged in and on wifi if possible as its a 300+mb file. Also 4.4.3 is actually out now so you have 2 updates
I did so .. several tiimes .. says i am up to date ..
