Kit Kat Upgrade has Changed Speach-to-Text Function
  • 2 July 2014
  • 1 reply
  • 20 views
I have a Samsung Galaxy S4 Mini and ever since the Kit Kat upgrade, my speach-to-text function does not capitalize the letter "i" when it is used by itself. So far, this is the only keyboard/talk & text bug that I've found. Has anyone else encountered this issue? If so, is there a fix for it? Thanks. John
Best answer by Vincent 2 July 2014, 14:44
Hey John! You should check directly with Google. Find support contact info from this link: http://koo.do/1xgKzmA. Thanks. ________________________ If you see a good answer, give it a star.
1 reply
Userlevel 2
