kakaotalk problem !
i've just downloaded kakao and whenever i write my number and press "done" says it can't connect to the server, what should I do? (I've already checked my number and it's correct)
Is your data on our is wifi connected?
Yes it is
Uninstall the app and restart your phone Re install the app and try again
In KakaoTalk's app review section, many users are complaining that as of the last update on August 25, 2015, the app crashes or doesn't work at all. I don't see the problem you're having mentioned, but it could stem from this recent update. You could try uninstalling and re-installing the app to see if that makes any difference. Edit: didn't see Chad's post till I finished mine.
https://play.google.com/store/apps/de...
My kakao
