Japanese Phone IS it compatible?
Friend is sending me a Freetel MUSASHI Dual SIM LTE FTJ161A from japan. and I would like to Know if it will work on koodo? would it get data?
Best answer by rikkster 26 June 2016, 10:53
Hi Jorge, No, the phone will not be compatible with Koodo. Telus and Koodo do not operate a 2G GSM network. For the phone to work, you would need to see Bands 5, 2 and 4 or 850/1900 MHz & 1700/2100 MHz (AWS). Japan uses Band 6 for 850 MHz but utilizes a different set of uplink and downlink radio frequencies compared to that of Canada's Band 5/850 MHz. There's no LTE either as the frequencies for that band are incompatible. Koodo operates on the TELUS network. https://www.frequencycheck.com/compatibility/AaalHdx/freetel-musashi-dual-sim-lte/canada
1 reply
