Is the sony xperia m2 compatible with koodo's lte network?
Hello, Is the rogers/fido sony xperia m2 compatible with koodo's lte network? The lte bands this phone has is 700, AWS, 2600 MHz. Thanks
You could try to check it here, although it's not alwyas accurate: http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/how-do-i-know-if-my-phone-will-work-on-the-koodo-network Koodo now unlocks other phone companies' phones too (only at koodo stores) so if you opne a new line with them and the Experie model is compatible they will look after everything for you.
Does koodo even HAVE LTE sim cards?
All Koodo's SIM cards are LTE enabled, at least the ones they are selling now.
Koodo's LTE is AWS (1700), so that phone should work.
