Is Nexus 4 an unlocked phone?
  • 27 September 2013
  • 6 views
Is Nexus 4 an unlocked phone? What is the difference between Nexus 4 in the Prepaid Phone section and the one in regular Phone section?
Hey Lissa. Yes its a phone that google has already unlocked before sending them off to koodo
There isn't a difference in the Prepaid or Postpaid section. It's just depending what kind of service you are wanting.
Except the Prepaid Nexus 4 costs $50 more than the Postpaid Nexus 4
LIkely because they "subsidize" that 50$ difference into the Monthly Plans hoping most customers stay with Koodo & don't simply buy it on Pre-Paid then leave.
Great, just got the phone from Koodo. Works really good! Thanks guys 🙂
