Is it possible to use the 28$ plan if i already have my own phone?
i have my unlocked samsung galaxay s3 and i would love to reactivate it with the 28$/month plan, is this possible? and do i need a credit card even on self serve on that opperation?
Yes to your first question. If you're currently a customer, then you can make the change yourself via Self Serve. No need for a credit card.
Userlevel 3
Hey Yoann,
Are you an existing customer and you want to change your plan to the $28 or do you want to activate a new line?
Many thanks!
