is it possible to change prepaid boosters on prepaid self serve or do i have to call in and get it done
just want to change my data booster... can i change it on self serve or do i have to call in to get it done
By change do you mean purchase more? If so then yes you can do all this on Self Serve https://prepaidselfserve.koodomobile.com/
no, i have the data 100 booster at the moment, i want to change it to the 500. can this be done?
Unfortunately not. Once a booster is purchased, it is purchased. However you can try to call Koodo to see if they can help. *611 on your koodo cell. It's a free call
