Is it possible .... if i already have a prepaid koodo phone to use a unlocked phone
Sure you can use an unlocked phone with Koodo (as long as it works with Koodo).  You do not have to use the phone that you purchased with Koodo
All u have to do is swap the sim card from your Koodo phone to your new phone
thank you
