Internation Unlocked Phone won't connect to American Network while traveling from Canada to the USA on Koodo
  • 23 February 2015
  • 2 replies
  • 19 views
Hi! I owned an international unlocked LG G3 that I bought in the US and activated in Canada. In order for the data to work I had to activate APN. Now, I am travelling to the USA but the phone is not finding any affiliated american network. I am not even talkig about data, but simply sms and calls. Can somebody tell me what I need to do as I am stuck with a phone and a US plan TNT30 that I just bought from koodo, but can't use it.
Maybe this will help : http://support.sprint.com/support/article/Troubleshoot_issues_related_to_data_connectivity_and_your_LG_G3/WTroubleshootingGuide_542_GKB74066-Trend?INTNAV=SU:DP:OV:TSIS:LgG3:TroubleshootIssuesRelatedToDataConnectivityAndYour Restore default APN : http://www.itjungles.com/lg-g3-how-to-restore-default-apn-settings.html
And you're not in prepaid right? Make sure network selection is set to automatic
