incorrect spelling when dialing out NOT "dialling" out
When I dial out on my Samsung Android, the spelling of "dialing" is incorrect.  The correct spelling is [b]dialing and not [b]dialling.  Always been a pet peeve of mine whenever I call out.  This tidbit of info should be worth something??!!
This is a samsung error from their phone. If there is an update available for your phone, this error might be corrected. Just make sure you download the OS update via wifi as not to use up all your data
If there is incorrect spelling there are many reasons one may be old software upgrade but some times wen you do a upgrade make it worst make shour you phone samsung tell thim what going on simple do hard were reset may help like allway send your phone in let thim take look at it is software should be 44.2 next update untell September I think??
If there is incorrect spelling there are many reasons one may be old software upgrade but some t...Not sure how you know what version of Android their device is running considering they never stated what phone they have
Userlevel 2
If there is incorrect spelling there are many reasons one may be old software upgrade but some t...Didn't know there was already a 44.2 update! My z1 is super behind!! 😉
travelling = traveling 🙂
"Dialling" is correct in Canadian English. "Dialing" is American.
