Incompatible Phone Issues
I have an HTC G2 phone from the States. Now that I live here I want to use a Canadian SIM card with it. Koodoo says this phone is incompatible with their network. Does anyone know a compatible network for my phone?
try Fido , Rogers or wind. But the plan are not intersting as the ones offred by Koodo 😉
try Fido , Rogers or wind. But the plan are not intersting as the ones offred by Koodo ;-)Fido/Rogers will only offer EDGE (2G) speeds, which are unusable for anything other than the most basic browsing. Your only options for that phone are Wind Mobile (select large cities) or Videotron (Quebec-only).
try Fido , Rogers or wind. But the plan are not intersting as the ones offred by Koodo ;-)You can get compatible phone from Koodo for 0$ with Tab plus doubled Plans, hurry before promotion expiry date : https://shop.koodomobile.com/plans/plans/index.html
