Incoming call from home goes straight to voicemail
  • 20 October 2020
  • 4 replies
  • 41 views
Samsung Galaxy A5. All incoming call from my home # goes instantly to voicemail without ringing and the call log shows that I missed the call. The phone rings for all other incoming numbers. Very frustrating!!!
Best answer by Dennis 20 October 2020, 00:26
Check your phone app, do you have that number blocked or restricted?  Di you have do not disturb mode on?
Check your do not disturb settings. Also verify that your phone is not set for auto forwarding of calls to your email (if it is, cancel it)
Call Forwarding type
Description
Activation code
Deactivation code
Call Forwarding unconditional
Forwards all incoming calls to another number
*21*
#21#
Call Forwarding busy
Calls will forward only when you're on the phone and the line is busy
*67*
#67#
Call Forwarding unreachable
Calls are forwarded if your phone is turned off or out of a coverage area
*62*
#62#
Call Forwarding no reply
Calls will get forwarded only if your phone rings and is not answered
*61*
#61#
Also check your call waiting settings, airplane mode setting and network signal strength when calls go straight to voicemail.
Issued solved. Thank you for your help.
I check on the # and noticed the option “Do out route to voicemail”. I clicked on it and now the incoming call rings.
