In airplane mode, can my LED flash when I get a voicemail?
  • 17 August 2014
  • 1 reply
  • 53 views
I have an android Samsung Galaxy S3, and like to keep it in airplane mode ...the problem is that if someone calls and leaves a voicemail, I won't know about it until I turn the airplane mode off, which I may not do for days (as I'm not a frequent user of the phone, and this way preserves the battery power, and I don't get unsolicited calls!)
Best answer by John Lee 17 August 2014, 01:59
Unfortunately, I do not believe your LED will flash when you get voicemail when you have airplane mode on. Airplane mode disables all cellular connection so the device would not know that it has received a voicemail unless you put it turn airplane mode off.
1 reply
