Im gonna be out of canada for 3-4 mmonths and wont be using my number. How can i freeze or pay the least expensive plan?
Best answer by Mathieu 10 May 2015, 01:37
Hi Emre, You can change your plan to a seasonal hold which will cost you 15$/month. If you have a grandfather plan, you will loose it so just consider that before you actually use the seasonal hold. Hope this helps!
1 reply
