If I keep my prepaid account active with automatic top ups can I forward the number temporarily to another number
I'd like to be able to forward my current number on a prepaid 15 plan to another number for several months.  Can I do this as long as I keep the current prepaid active with automatic top ups?
Yes, but you'd need an active booster as well... because forwarding your number would mean using up minutes.
Sophia wrote:
Yes, but you'd need an active booster as well... because forwarding your number would mean using ...
Is call forwarding once again working on prepaid? From what I last heard it wasn't.
Have yet to see prepaid call forwarding codes work with my account. There is no provisioning to nick the client for a forwarding fee. And I can't believe it's free on prepaid.
If it does work, it gets expensive very quickly. See other folks' experiences on this forum on post-paid.
Original poster should go thru the motions and see if you can get a test call to work. That should settle the question to thier satisfaction.
http://help.koodomobile.com/plans-add-ons-data-and-other-services/calling-features/how-do-i-use-call...
That's fine. Thanks very much.
